the procharger thread
Old Apr 23, 2012 | 01:02 AM
AndysC3's Avatar
Default the procharger thread
Just wondering who was running a procharger. List your Engine, cam, trans, torque converter, p1sc or d1sc, pulley size, how much boost and shift points and track results.
Maybe this will help someone out who is unsure about going with a procharger.
Old Apr 23, 2012 | 02:15 AM
08cheyennesc's Avatar
08 CCSB 5.3
P1 ,3.4" RR pulley,12# @ 6000 shift points
214/222 .559/.566 115lsa,Yank SC300 ,built 60E,4.10s,
8.38@84.38mph 1/8 ,no 1/4 time
Old Apr 23, 2012 | 07:25 AM
BlueSSS's Avatar
04 Silverado SS
6.0 with 6.2 topend, P1, 3.5" RR, 218/232, FLT lvl 6, circle D 3200, 6# no track times yet. Shifting at 6500
Old Apr 23, 2012 | 08:39 AM
ak2007r6's Avatar
2011 CCSB 6.2
D1SC
4.38"
3 core intercooler
65lb Fast Injectors
Stock Transmission
Stock CAM
Stock Stall
Seeing 12lbs on the 1-2 shift and around 10 after that at WOT
No track times yet
Old Apr 23, 2012 | 09:43 AM
zachm89's Avatar
6.0L LQ4, LS9 head gaskets and ARP head bolts, Lunati 227/233 113LSA cam, built 65e, PATC 3600 10.5" converter, D1sc 3.85" pulley saw around 15psi on the old motor (LQ9), shifted around 6800. New setup will have two tunes, shifting at around 6200-6400 on the street and only about 10-12psi. Track tune will shift around 6800-7000 and hopefully around 15-18psi on a 3.7" pulley. We'll see how she holds up...
18psi on a stock bottom end 6.0L
Old Apr 23, 2012 | 10:12 AM
shanesss's Avatar
old set up:
LQ9, full exhaust, stock cam, built 60e, 2500 stall, D1sc 3 core, 60# injectors, 3.85 pulley and was seeing about 10 lbs at 1-2 shift, shifting at 6100. 12.9 @ 106 1/4.
Old Apr 23, 2012 | 11:24 AM
Superado's Avatar
11 Second Truck Club
Old set-up:
LS1 - 8.9CR - Patriot Stage III heads / Patrick G spec'd, Thunder Racing core, Comp Cam - 218/230 .605”/.604” 112LSA +3 advance (with 1.7 ratio rockers) Comp XFI/XFI high lift lobes / 4L80e / PTC 3200 - 3400 / D1SC / 4.0 pulley / spiked @ 13#'s / 6500rpm / 11.94 @111.62 / still had plenty left in her...started fighting fueling issues
New set-up (changes):
9.5 CR / Thunder Racing "TRuTorq" Level 5 - 227/239 .614/.621 115 LSA / 3.4 pulley / dyno & track results soon
Old Apr 23, 2012 | 11:35 AM
idahoblkss's Avatar
2004 silverado ss
6.0l 4l80
3200 tcs converter
220-224 581 581 115 comp cam
D1 W/ 3.7 @ around 14psi
corn fed (e85)
shifting @ 6400rpms
1.8 60ft 11.4 @ 120
Old Apr 23, 2012 | 06:33 PM
AndysC3's Avatar
Our trucks are almost identical lol. I doubt that I'll take it past 13-14# once I get my procharger.
Old Apr 23, 2012 | 07:15 PM
Mangled03gmc's Avatar
Baltimore Whore
6.0, Lt's, no cats, single 4'' exhaust
317's mild head work,
comp 224/588/112 lsa,
3200 verter,
410's,
front mount 3 core,
ruffly 12lbs
shifting @ 6300..
