Procharger set-up
Superado what would happen if you leave the pcv valve and hose all in place [like stock] and only vent the crankcase at the oil fill hole.I also heard of tapping hvac[I hope this is the right abbreviation] line for vacuum.Is this good info.?
I finally got my install manual in the mail about 5 mins. ago.Now I understand all of the responses much better.They[procharger] leave the pcv alone [all stock] and vent off the passenger side valve cover and block the tb connection.What if I don't touch any stock connection [even leave the tb line hooked up] and only vent from the oil fill hole?
You also need to check and see if your pcv valve is a fixed oriface or a plunger style. The fixed oriface could lead to crankcase pressurization also.
