Procharger pullies on a D1SC
Old Oct 1, 2007 | 08:02 AM
sharpshooter's Avatar
Default Procharger pullies on a D1SC
Right now I am running a 4.25 pulley on a D1SC on a internally stock 5.3.It peaks out at 9-10 psi of boost at my shift points.What would I see boost wise if I drop my pulley down to a 4.00 and is this to much for a stock 5.3?
Old Oct 1, 2007 | 08:48 AM
NegraRCSB2X4auto's Avatar
I would say that would be the limit to stay on the safe side but a good tune is what's going to make or break how much psi you run.
Old Oct 1, 2007 | 12:34 PM
Which would be the limit the 4.25 or the 4.00?
Old Oct 1, 2007 | 02:12 PM
ranwalk's Avatar
That would most likely net you around 13 psi if you are now seeing 10. I wouldnt do it on a completely stock 5.3. Put a meth kit on it then switch to the smaller pulley.
Old Oct 1, 2007 | 08:01 PM
badnoma's Avatar
wow. I ran the 4" pulley on my 4.3 with the prochrager and i only seen about 9psi. You have a full liter more displacement and you are at the same boost. ?????
Old Oct 1, 2007 | 08:05 PM
nightrunner's Avatar
Mr. Obvious
badnoma, did you have the same blower? did you have a cam or other internal work? did you have aftermarket exhaust or headers? all this will decrease boost levels but increase HP
Old Oct 2, 2007 | 05:18 PM
Blown06's Avatar
8 Second Truck Club
I don't know if ya'll remember my last set up. Bone stock 5.3, D1sc 4.00 pulley, 3-core intercooler, 44lb. inj., 255lph intank, custom 4" cat-back, tuned by MTI. It made 12 psi on the dyno and 14 psi on the road at the 1-2 shift. Made great power for two days then BOOM! Killed the #7 piston. I think it would have lasted longer if the tune wasn't so aggressive. Power was 440rwhp and 450 rwtq.
Old Oct 3, 2007 | 12:12 PM
I'll stick with the 4.25.thanks
madmann26
Apr 29, 2020 09:17 AM
murderedSS
27
Oct 12, 2015 11:13 AM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
hackrst
Sep 2, 2015 05:27 PM
