Procharger loosing boost
Old Nov 15, 2014 | 04:18 PM
  #21
lsxperformance's Avatar
Originally Posted by YenkoST
Could timing cause this but having low timing or a bad ignition module? I had a spare MAP sensor 3 bar laying around and tried that one. It shows the same.
No not 6psi typically it really only changes a very small amount with timing. Mechanically cam and valvetrain parts, as well as exhaust are gonna be large players in how engine builds boost because it effects dynamic compression, static compression does some too. I was just trying to help you figure out if it's a mechanical issue or if there is something not right with the setup before the engine, before you go on a wild goose chase or worse start swapping parts...
Old Nov 15, 2014 | 04:33 PM
  #22
YenkoST's Avatar
Well, I went back around the truck today, I have a new tune with more spark to see if that was an issue of firing too late, air filter straight on the housing, and also tightened all clamps down again this time with a 3/8" ratchet instead of 1/4". Found one tubing where the bead wasn't pushed down passed the clamp so got that corrected as well.
Bout to go for another pass in a few, will come back with more information.
Old Nov 16, 2014 | 11:17 AM
  #23
YenkoST's Avatar
Well, its now making 6 psi all the way to the shift point. So, it either had to be the clamp or intake restricting it.
Old Nov 16, 2014 | 12:30 PM
  #24
03sierraslt's Avatar
I would guess the intake.
Old Nov 17, 2014 | 11:41 AM
  #25
ProChargerTECH's Avatar
FormerVendor
Glad to hear your issues are resolved.
Old Nov 18, 2014 | 10:09 AM
  #26
Thought it was a 9-10psi pulley? Still much better tho
Old Nov 18, 2014 | 08:38 PM
  #27
YenkoST's Avatar
Was anticipating 8-9 psi but the engine could be eating it up. Going to go down to a 8 degree plug as the plug is hot then see what it makes a little higher up.
murderedSS
27
Oct 12, 2015 11:13 AM
2500ZL1
Sep 12, 2015 03:50 PM
Justin87gn
Sep 10, 2015 12:06 PM
Pimpinpete
Sep 8, 2015 07:39 PM
06murder
Sep 4, 2015 03:54 PM
