Procharger intercooler pics
Old Apr 13, 2010 | 09:41 PM
eddie nelson's Avatar
Default Procharger intercooler pics
Having hell installing this factory procharger 2 core intercooler. Any pictures of your install? Need some ideas for my 05 sierra denali.
Thanks
eddie
Old Apr 13, 2010 | 09:52 PM
allballz57's Avatar
I have pics of my 3 core front mount! I never liked the horizontal design from procharger,so I moved mine behind the grille.I like it much better and it took a couple bends out.I also got rid of all the rubber elbows that like to balloon under boost.It made boost come on faster and peak a little higher.
Old Apr 15, 2010 | 06:30 PM
Send me some pictures.
Old Apr 16, 2010 | 04:41 PM
02'Z71ONDUBZ''s Avatar
Post pics online, I'd like to see your FMIC setup as well
Old Apr 18, 2010 | 07:18 PM
I decided to copy off of Mangled (I be riding dirty)s truck. I like how the ic is vertical and mounted in the bumper (airdam). The ic im running is a procharger with the inlet is at the bottom and the outlet at the top. With that setup the outlet doesnt clear the passenger side frame. I have my ic at a welding shop. Im having the outlet moved to the bottom of the ic to clear the frame. I hope it turns out ok. We'll see? When it comes back i can start on my install. Cant wait!
Old Apr 18, 2010 | 08:55 PM
allballz57's Avatar
Here are some pics,I ended upswitching to an ebay intercooler that had the inlet and outlet on top and all hard pipe without rubber elbows,but now I am going air/water so I don't have this setup anymore.when I did this I wanted to get plenty of air through the grille since my bumper cover didn't seem to have much airflow for the intercooler. I offset it to try not to obstruct the radiator too much.
Old Apr 18, 2010 | 09:30 PM
Mangled03gmc's Avatar
Baltimore Whore
Old Apr 19, 2010 | 12:29 PM
JJB's Avatar
JJB
I like this mount mine ...I may try to do something like this with Mine
Old Apr 19, 2010 | 05:59 PM
I like the set up of allballz but im scared to block the radiator pulling a 5000lb boat in louisiana heat. I hope to have my ic back by weds. Ill take some pictures when i get it.
Old Apr 22, 2010 | 10:03 AM
Superado's Avatar
11 Second Truck Club
NEVER had ANY issues with a horizontal mount FMIC...jus' sayin'...
