Procharger help!
Old Jan 22, 2011 | 11:39 PM
casper02's Avatar
Default Procharger help!
Ok guys got it all up and finished but the thing wont stay on? Wtf im seriously getting agravared could it be cause of the cam? This was an na setup b4 switched the heads for compression drop and thats it could it be the cam lsa its a 113+4 and I switched to 60lbs and got my tune rescaled for them. What can it be any suggestion tune maybe?
Old Jan 23, 2011 | 12:05 AM
Mangled03gmc's Avatar
Baltimore Whore
what isn't staying on?? The belt, the tune??
Old Jan 23, 2011 | 12:21 AM
casper02's Avatar
The truck itll crank start and shut off
Old Jan 23, 2011 | 12:56 AM
Baltimore Whore
Did you have any security issues, or is the security light on in your truck>> The blower shouldn't have anything to do with that..
Old Jan 23, 2011 | 02:47 AM
Blown06's Avatar
8 Second Truck Club
Does it say reduced engine power? Have you had your pcm recalibrated for the 60lb injectors?
Old Jan 23, 2011 | 02:52 AM
casper02's Avatar
Well heres the deal its an 02 so I dnt think it goes into rep mode and yea I took it by my tuner wasnt there so the mechanic rescaled them im thinking mayb he didnt do it right?
Old Jan 23, 2011 | 04:04 AM
Most Hated's Avatar
calm down count to 10
1, 2 , 3 , 4 , 5 , 6 , 7 , 8 ,9 10 take a deep breath
how does that feel ?
firt of all get ur tuner to tune it , then start from there try spraying some starter fluid in the tb if it turns on for a bit then it might be ur f pump if not chek ur maf check ur coils check everything
Old Jan 23, 2011 | 04:10 AM
idahoblkss's Avatar
Sounds like a tune problem
Old Jan 23, 2011 | 02:33 PM
phasemaster1's Avatar
Try starting it NA just pull procharger tube feeding intake before MAF if you have one. When I installed mine using NA tune truck would lean out and stall at idle.
Old Jan 23, 2011 | 02:37 PM
Sanster's Avatar
My 01 would do the same thing it was the security system that was messed up on it. would fire up and stall right away. i would either have to disconnect the battery to reset the computer.
