Procharger help!
Old Jan 23, 2011 | 07:04 PM
casper02's Avatar
Mmm ill try that tomm morning cause im getting frustrated lol
Old Jan 23, 2011 | 07:06 PM
casper02's Avatar
Any othrt ideas
Old Jan 23, 2011 | 07:17 PM
lablackbeast's Avatar
doesn't know what quit means
It could be if you didn't tuned it .... at first mine started perfectly, left it on for about 15min and then when I put it in gear it would shut down ..... then I got my computer in the mail from my tuner (mail in order) and I stood on after that .... I drived badass I will give it a little gas a 9psi will be build right away and it felt bad *** .... I had the 4.0 pulley on a D1 ... BUT I had a cheap as belt since I was gonna go with a smaller pulley and it thru it and broke my tensioner .... so I sold it for the right price
Old Jan 23, 2011 | 07:22 PM
casper02's Avatar
I hope well see mon guys any other info is greatly appreciated
Old Jan 23, 2011 | 09:09 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Does it have any codes being set?
Have your tuner turn vats off just to be sure.
Is this truck sd tuned or maf tuned?
Make sure fuel pressure is around 55psi with key ON.
Old Jan 23, 2011 | 09:46 PM
casper02's Avatar
Supposed to b maf tuned and I have my fuel pressure regulator set for 60psi and ill have edgar turn the vats tomm as for codes none
Old Jan 24, 2011 | 02:12 PM
casper02's Avatar
Ttt....
Old Jan 24, 2011 | 02:21 PM
Mangled03gmc's Avatar
Baltimore Whore
Pull the intake tube off
Old Jan 24, 2011 | 02:23 PM
casper02's Avatar
Will do john ill get to u in a bit
Old Jan 24, 2011 | 02:57 PM
Baltimore Whore
Yah if you pull it off, it still does the same thing as with it in then you can kinda rule the blower being a issue out of it..
