Procharger guys, step inside...
What have yall done with your red junction box? Mine is just hanging around... I have it ziptied now so it doesnt rip off of my alternator. Im sure its fine but just seems there should be a better place for it.
My pcm is still in stock location, but wheatley is sending me out another one and its a PITA to get to... How and where are yall mounting it?
My red thing is moved to make room for the compressor. What kind of numbers are you putting down. I have the same set-up as you less the cam and 3200 stall
11# I am spraying meth and getting 425whp @ 10* timing.
Mine red thingy is in the stock spot
My red box bracket is removed and is zip tied out of the way.I also modified the pcm bracket to move it for more clearance and it still allows me to use the factory clips to hold the pcm.
I relocated my pcm by removing battery and running my procharger plumbing as required. I made the pcm bracket fit as required. I ended up dotco-ing the back factory mounting frame off the back. Using 1/8" x 1" flat aluminum i bent up brackets to support it accordingly. I am still able to clip it in and out and the cover still fits too. I painted the aluminum brackets black to blend and look more factory. Here are some pics if you can see them. Oh, and my red box is just zip-tied tight and out of the way. Will find a better solution soon. Hope this helps.
lxcoupe
Jul 21, 2015 02:12 AM
