Procharger Guys come in!!
Old Mar 29, 2010 | 08:55 PM
wentbig's Avatar
Originally Posted by allballz57
he as a D1,not a P1! he will get 10psi with a 4"! doubt he could run a 3.25 without a ton of belt slip,if you can boost would probably be 16-20 psi with a D1.
Yur right. we can't have the D1 in Kali
Old Mar 29, 2010 | 09:24 PM
Mangled03gmc's Avatar
Baltimore Whore
That suks but the P1 isn't no sloutch
BTW you said your running a 3.25 pulley, seeing 11psi.. What is you exhaust, engine set up.. How much is the belt slipping. My belt would slip horrible with a 3.60 pulley untill I reconfigured the pulleys..
SORRY TO JACK UP THE THREAD
Old Mar 29, 2010 | 10:01 PM
gao8302's Avatar
Ok so i got the belt today....
But im wondering whats the best way to get this push lock fitting to attach to the intake for the bypass. I see the intake has a twist off on it but the push lock is 1/4 NPT. If anyone has a pick of how they installed it i would like to see it.
Just waiting on the fuel pump to get here. Bosch 044 intake. And the 2 bar Map sensor. Almost GAME ON BOYS!!!!
Old Mar 30, 2010 | 11:10 AM
Raffman's Avatar
You really have to drill and epoxy a fitting for the intake. If you don't want to go that route use one of the slid on fittings on the intake just make sure its tight and use a tie wrap on it. The race valve is no problem for the push lok. When you go into boost you don't want it blowing off.
Old Apr 4, 2010 | 10:13 PM
danbap's Avatar
any updates?
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
