Procharger experts (and anyone else!!)
Old Nov 1, 2006 | 02:02 PM
SCIV's Avatar
Default Procharger experts (and anyone else!!)
This is a question about the efficiency of a P1SC versus a D1SC. I know a S/C takes HP to make HP, and I believe the D1 is more efficient than a P1. I think the P1 is a radial design and the D1 is a spiral design, so does the D1 make more power at the same given boost level as a P1?
So my theory is that with a D1 at 12 psi would yield more HP than a P1 at 12 psi. Is my thinking correct? If so, does the additional power come from the more efficient design, or it just takes less power to turn the D1? Or both?
I am trying to weigh the pro's & con's of upgrading my P1 to a D1, and was thinking out loud about the performance increase, if any, of just making that change alone (with any tuning adjustments).
Thanks in advance guys,
S.C.
Old Nov 1, 2006 | 06:06 PM
MHSLOT12's Avatar
Default I M O !!
Boost Is Boost 12lbs Is 12lbs !!!!
Old Nov 1, 2006 | 06:11 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You are so wrong its not even funny, Im not even going to bother explaining.
Old Nov 1, 2006 | 07:32 PM
SCIV's Avatar
Damn Cody, you'll be in the 10K post club by tonight!!
Anyone else care to share?
Old Nov 2, 2006 | 01:41 PM
SCIV's Avatar
Wow, nobody??
Old Nov 2, 2006 | 06:13 PM
1slow01Z71's Avatar
Think of the prochargers as turbos. Bigger turbos create less heat at the same boost level allowing you to run more timing and lower IATs are the main benefits I see of upgrading.
Old Nov 2, 2006 | 07:10 PM
TG02Z71's Avatar
Dude...don't even tell me I need a new turbo now too!!??!!??!!??
He is right though, boost is not bosst.
Old Nov 2, 2006 | 07:12 PM
1slow01Z71's Avatar
Gotta have a new turbo for a new motor
Old Nov 2, 2006 | 07:18 PM
SCIV's Avatar
My IATs aren't bad in my book. Only like 20* above ambient on a WOT run.
I just wonder if it takes 40 HP to turn the P1 to make 10 psi, that a D1 would only take 20 HP to make the same? Those numbers are just for theory, I have no idea how much it takes to run those.
Thanks for the input Cody, I was starting to think people don't like me!!!!
Old Nov 2, 2006 | 07:25 PM
TG02Z71's Avatar
We all love anyone is is foolish and crazy enough to try and make a truck go fast, start saving your money for all the **** that will happen once you get boost hungry and 5-6psi is not enough...just ask Cody.
