Procharger Coming
Old May 29, 2007 | 05:47 PM
llfirefighter's Avatar
Default Procharger Coming
I Was Curious Of What Kind Of Numbers Will I See With A D-1sc Procharger Kit With About 10 Psi Boost. I Put Down 406hp And 393tq
With Head And Cam.
Old May 29, 2007 | 06:14 PM
ranwalk's Avatar
What compression is your setup? I'm at 9.1cr, I dynoed 640rwhp with 14psi and a D1.
Old May 29, 2007 | 11:11 PM
tarinitup's Avatar
9 Second Truck Club
550-600+ depending on tuning and if your lq9 holds.
Old May 30, 2007 | 08:52 AM
Bad_Apple's Avatar
thats what Im looking for when I get my Head/Cam Lq9 installed 550-600 range....
Old Jun 1, 2007 | 07:11 AM
I talked to jason at texas speed and performance he told me that I would have to forge the engine to handle the hp. So now I going to have them build a 408. Then maybe a 150 shot.
Old Jun 1, 2007 | 07:15 AM
Tarinitup what shot are you using on your 402?
Old Jun 1, 2007 | 09:19 PM
tarinitup's Avatar
9 Second Truck Club
I'm using a 150 shot since I moved to the ls1 nitrous plate. It runs the same as a 200 shot on my old single nozzle. Your truck willl do really nice with boost and nitrous. Are you also going to do the 4l80e tranny conversion? Let me know when you come down to penwell in your new setup.
Old Jun 2, 2007 | 01:23 PM
The Cash Flow Is Low So Im Am Going To Put A 150 Hp Shot Of Spray On The 408. I Have A Built 4l65 It Will Hold. You Have Good Numbers I Hope To Come Close To Them Maybe.
Old Jun 2, 2007 | 04:49 PM
tarinitup's Avatar
9 Second Truck Club
I'm sure your times will be the same or better. what are the details on the 408 like cam, CR, and heads. I recommend a little bigger cam than my 228 230. It has a good lope and low end is bad *** but it kinda dies down above 5600 rpm because the truck intake it is a pretty bad restriction. One of these days I'll put on an ls6 intake and bigger cam.
Old Jun 3, 2007 | 10:04 AM
the cam is going to be 232/234 595/598 112, heads are dart pro one, cr 9.5, I have a 6.0 truck intake but would it be better to go with a fast intake.
D1SCSS
Jan 25, 2016 10:14 PM
mzoomora
Jan 3, 2016 07:06 AM
JCW
Sep 22, 2015 03:59 PM
rebel_within
Aug 25, 2015 11:49 AM
fcompean
Jul 15, 2015 09:55 PM
