procharger and cats
I run a 4.25 in. pulley on my D1SC with stock cats and I see 10# of boost at 5800 rpm.If I remove the cats could I run a 4.00 in. pulley and build boost at a lower rpm and still see 10# at 5800.I really don't want over 10# peak because my 5.3 is stock.
A higher stall converter is the ticket with a centrifical. I've tested my truck out up to a 5,000 stall. What a head rush! lol I've settled for a 3,700 stall. 4,000 was just a tad much for a DD. If it was my decision...I'd yank the cat's and stay with the 4.25" pulley first. If your not happy with the results, then pulley down.
Pardon my ignorance, but what are the implications to launching if you have a higher stall converter? I just bought an Escalade wih a Procharger and it takes a while to get going then goes like a violated ape!
So can you get the RPM's up without braking to a certain point and then beyond that point you begin moving? And have a head start on the RPMs?
Sorry for my ignorance on this topic.....
edit - I get it now!!!!!
http://www.autogeek.com/news/Transmission1.pdf
What stall speed for me? Need a built tranny for this? Assume so....
