procharger 3.85 pulley
Old Apr 6, 2014 | 11:16 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by gamble686
Any chance your tensioner is messed up?
I'm running a HD TENSIONER
Old Apr 6, 2014 | 06:16 PM
sharpshooter's Avatar
Sureshot runs the newer style bracket like you. He said he used to run a 114" belt with a 3.6" pulley. I'd say a 114" should be good with a 3.85.
What is your belt part number?
Also did you modify the aluminum spacers that get used with the alternator bolts? There's a mod to do to them so they can hold the alternator tightly.
Old Apr 7, 2014 | 11:44 PM
KO61140HD is what i had on it I'm gonna try a 5061130
Old Apr 8, 2014 | 08:33 PM
when I go up or down in size on my procharger I swap out the idler pulleys or even the tensioner one for larger or smaller ones to compensate for the difference in size...always using the same size belt
Old Apr 8, 2014 | 10:15 PM
i ended up getting a 113" belt but it won't fit no way no how a 114" is perfect theres about 1/2 to 1 inch before the tensioner bottoms out before it tightens up on the belt
I'm running the stock size idler pulley which i think is 90mm iirc
madmann26
Apr 29, 2020 09:17 AM
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
