procharged yukon high iats!?
Old Sep 20, 2011 | 10:04 PM
xxbmxlsxx's Avatar
Default procharged yukon high iats!?
04 yukon 5.3. cammed built bottom end.circle d convertor and built tranny. seeing about 8psi on a p1sc. top of first gear i start seeing 130+ iats and truck starts pulling timing. saw 140 max i think in high 2nd when doing a holeshot. what should i do? relocate iat?
also can i can get a 160 degree thermostat for this? i would like to cut out as much heat as possible
Old Sep 20, 2011 | 10:20 PM
Mangled03gmc's Avatar
Baltimore Whore
I take it this is the reg 2 core and not the upgraded one???
Old Sep 20, 2011 | 10:23 PM
xxbmxlsxx's Avatar
i would assume so. it was on the truck when i got it
Old Sep 20, 2011 | 10:25 PM
08cheyennesc's Avatar
I relocated the 3 core procharger intercooler from the bottom (flat angle) to the front of the radiator using the same tubing and on a 100* weather the iats were 180*, on 10# of boost.
Old Sep 20, 2011 | 10:29 PM
Baltimore Whore
Yah has to be, that is pretty hot.. I have a 3 core, front mount under the valance, on 90-95 deg days I never saw my iat's go over 110.. You need to upgrade the cooler..
Old Sep 21, 2011 | 04:15 PM
xxbmxlsxx's Avatar
so whats the best intercooler i can fit in the front of this thing? the procharger ones seem to not do the job and i shouldnt need meth for 8-10psi.
Old Sep 26, 2011 | 04:12 PM
xxbmxlsxx's Avatar
i cleaned out and remounted the intercooler so it could get more direct air, then cleaned my maf and relocated the iat with a camaro sensor right by the throttle body. havent relogged it since relocating the sensor but the angle of the intercooler was good for about 20 degree drop. much better, didnt pull timing
Texas5.3_1251
Mar 5, 2016 08:10 PM
GMCtrk
Jan 27, 2016 06:47 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
00loudchevy
Sep 11, 2015 07:55 AM
Justin87gn
Sep 10, 2015 12:06 PM
