Procharged Silverado
Old Aug 10, 2009 | 08:45 PM
dmorgan's Avatar
Registered User
Default Procharged Silverado
Hi, I just installed a procharger in my 2004 Silverado HD 6.0 with the 4L80E and 4.10's. I was unable to use the FMU because the 04 doesn't have a return line so i installed 42# injectors and an MSD voltage booster. I reached up on top of the gas tank and got the wrong plug - I put 12volts by mistake to the evap solenoid. I got the check engine light and reconnected the solenoid and wired to pump to the MSD.
I still get the P0452 code and cleared it twice.
Did I ruin the solenoid and should I change it???????
I have a custom burn on the PCM and I want to go to the dyno but need to clear the code...
Should I gut the cats????
Don't want more codes and need to pass NY emissions.
Thank you for any and all help
Dan
Old Aug 10, 2009 | 08:50 PM
Mangled03gmc's Avatar
Baltimore Whore
You can gut the cats, have your tuner turn them off, you will get no SES light.. I would first try and unhook the batt for a half hour or so, see if shuts the light off.
Old Aug 10, 2009 | 08:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
if you gut the cats you'll never pass the sniffer...get hiflow cats if your really concerned. Welcome to the boards!
Old Aug 10, 2009 | 09:27 PM
MNC5's Avatar
Bet that runs nice, keep us posted.
Old Aug 10, 2009 | 09:59 PM
LsxCody's Avatar
Welcome.
Old Aug 11, 2009 | 04:25 PM
dmorgan's Avatar
Registered User
Changed the gas tank pressure sensor and that solved the code.
Plan to make brackets for intercooler and then a date for the dyno and another flash.
Expecting good numbers with this setup 9-10lbs.
keep you posted and will have signature and dyno pulls soon
Old Aug 11, 2009 | 05:44 PM
thunderwagen's Avatar
Welcome and good luck
Old Aug 11, 2009 | 08:39 PM
phasemaster1's Avatar
Dont gut the cats what size pulley?Idea on intercooler.
Old Aug 11, 2009 | 09:34 PM
turbosilvi's Avatar
thats exactly what my truck looked like when i was putn on my turbo kit. congrats on the pro! 9-10 lbs on a 5.3 should be a nice ride, good luck
Old Aug 11, 2009 | 10:56 PM
CJ Hungus's Avatar
The OP has a 6.0 so it will be even more fun than a 5.3
