Procharged Silverado
Hi, I just installed a procharger in my 2004 Silverado HD 6.0 with the 4L80E and 4.10's. I was unable to use the FMU because the 04 doesn't have a return line so i installed 42# injectors and an MSD voltage booster. I reached up on top of the gas tank and got the wrong plug - I put 12volts by mistake to the evap solenoid. I got the check engine light and reconnected the solenoid and wired to pump to the MSD.
I still get the P0452 code and cleared it twice.
Did I ruin the solenoid and should I change it???????
I have a custom burn on the PCM and I want to go to the dyno but need to clear the code...
Should I gut the cats????
Don't want more codes and need to pass NY emissions.
Thank you for any and all help
Dan
Dan
You can gut the cats, have your tuner turn them off, you will get no SES light.. I would first try and unhook the batt for a half hour or so, see if shuts the light off.
Changed the gas tank pressure sensor and that solved the code.
Plan to make brackets for intercooler and then a date for the dyno and another flash.
Expecting good numbers with this setup 9-10lbs.
keep you posted and will have signature and dyno pulls soon
