ported blower snout
Old Sep 7, 2019 | 11:28 AM
terravast4's Avatar
Default ported blower snout
Anyone out there port the snout the the TVS 1900 or 2300 to add a larger throttle body like a 112mm? did you gain boost? what kind of gains did you see?
Old Sep 7, 2019 | 12:48 PM
ZO6Ted's Avatar
No sir but larger intake gains boost. Larger exhaust lowers it.
Old Sep 7, 2019 | 03:14 PM
arthursc2's Avatar
The more air you can put in front of a blower, the more air she will compress: aka more boost.
I have an L67 Buick, I ported the M90 on my mill, put a 4" intake and 4" TB on it, on the same 3.4" pulley we went from peak boost of ~7.5lbs to a peak of ~11.2 according to the logs.
This is highly dependent on weather and air temp too, but with a weekends worth of work I gained closed to 4lbs by letting her breathe easier
dont forget to clean your air filter regularly as well, will help economy as well as boost. Ram air your intake if you can.
Old Sep 8, 2019 | 09:13 AM
MikeGyver's Avatar
It's been a long time, but I'm pretty sure that it was 1-1/2 psi that I gained by building a larger inlet housing for my blower to accept a 102 mm throttle.
Old Sep 8, 2019 | 09:25 AM
MikeGyver's Avatar
I had to look it up, I can't believe it's been 8 years. I gained 3 psi.
https://www.performancetrucks.net/fo...-block-458677/
Old Sep 8, 2019 | 02:46 PM
03sierraslt's Avatar
Ya. I ran a Holley 105mm on my 2300 with a 5” intake. Still have them both as a matter of fact.
Old Sep 8, 2019 | 02:57 PM
terravast4's Avatar
that's whatI plan on doing. what kind of gains did you see? did you port the snout yourself?
Old Sep 9, 2019 | 10:29 AM
Y-B-Slow's Avatar
Had a machinist friend port the snout of my 2300 to 104mm. Using a Nick Williams 102mm throttle body and a 5" intake. No hp data for that specifically as I made other changes at the same time but like others have said boost will increase.
GM1697
May 9, 2016 07:59 AM
PSM
Aug 17, 2013 06:30 PM
Ferocity02
Apr 20, 2012 04:14 PM
joeyc125
May 31, 2010 08:41 PM
redchevytruck
Oct 25, 2008 09:43 PM
