Plugs and wires
Old Jan 13, 2010 | 12:41 PM
Blownme's Avatar
Default Plugs and wires
I am fixing to change my plugs and wires on my 5.3 with a mp112. Magnacharger said to stay with stock plugs and wires. I see alot of guys running ngk tr6 and Taylor wires. Is this a better setup? Would any plug be good as long as it runs cooler than stock
Old Jan 13, 2010 | 01:29 PM
ducky's Avatar
TR6s would be better then stock
Old Jan 13, 2010 | 01:48 PM
hellbents10's Avatar
LS1Tech Sponsor
Tr6s with Scott wires would be the best.
Old Jan 13, 2010 | 02:33 PM
thunder550's Avatar
High on diesel fumes
Wires don't matter. Stock will be just as good as any of the aftermarket ones.
For higher boost applications TR6's would be better. If you're running just the standard 5-6 psi I'd stick with Magnacharger's recommendations.
Old Jan 13, 2010 | 02:47 PM
Blownme's Avatar
So if u go from a 7mm to 8mm size wire it wouldn't make a difference? Not trying to be a pain here just would like to know before I spend the money.
Old Jan 13, 2010 | 02:56 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
nope, wire is too short to make any difference. Mine are stock with TR6.
Old Jan 13, 2010 | 03:04 PM
thunder550's Avatar
Exactly. I was running stock plug wires on my (estimated) 700 rwhp turbo setup. No issues. Only reason I can see to buy other plug wires is if you want a different color.
Old Jan 13, 2010 | 03:17 PM
LS1Tech Sponsor
Or protection against heat!
Old Jan 13, 2010 | 04:03 PM
thunder550's Avatar
Fiberglass plug wire shields are a lot cheaper and will work better than new "thicker" plug wires.
Old Jan 13, 2010 | 04:07 PM
Blownme's Avatar
Thanks for the help, will stick with stockers.
