Please edge me on this?? MAF
I am pretty good with most of this stuff, but if my MAF sens is maxed out or close to it, what do I need to do get a new MAF? I don't no that it will be since the blower install, but what if it is or close.. Please let me know what I have to do inorder to fix it...
Thanks guys
John
Thanks guys
John
Mine max's out at 5300 rpm's with my D1SC but Justin can tune around it.He will add the fuel in your tune past the point it max's out.As long as you have large enough injectors and fuel pump.
John
You could put a MAF on there that is good for 10,000 HP but the PCM is limited to 512 g/sec. SD is another another story. I say get your **** going in 1 bar (what you have) and worry about blowing the MAF limits later. You'll be fine, especially with Justin behind the scanner.
So would a better MAF do it or will the SD be the only option
