Piping with 3/8 bung
Old Nov 7, 2018 | 02:04 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default Piping with 3/8 bung
Looking for some aluminum tubing to make an intake. Truck will be tuned SD so won't need a MAF, but will need a place for IAT sensor. I'll need a 3/8 hole in the intake tract somewhere. This won't be for boost but figure one of you would be the ones to ask.
Ive looked on siliconeintakes.com and they have a fitting to go in a silicone boot but I'd rather it go in the piping if possible.
Old Nov 7, 2018 | 02:26 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You just want the aluminum tubing to make your own intact tract not the physical intake?
Old Nov 7, 2018 | 03:05 PM
Hunt&Fisherator
Yeah. It's all in a '72 C10... I'll make my own intake. Needs to go to the driver front corner instead of the passenger anyway, the battery is over there.
Old Nov 7, 2018 | 03:49 PM
1FastBrick's Avatar
I don't Think you will find anything with a bung already welded in.
Summit has "Air Intake Tubes" For the piping and they also sell bungs as well.
Maybe Trick could help you out???
Old Nov 7, 2018 | 03:50 PM
Atomic's Avatar
I have a gauge for that
If you have an EGR equipped intake manifold a popular place is right there behind the TB.
Old Nov 7, 2018 | 06:26 PM
Hunt&Fisherator
Using the 90mm truck manifold. No EGR...... a drill bit could make a 3/8 hole though
I dug around the webz and found a fitting to put it in a silicone coupler. I'll just put it in the elbow directly in front of the throttle body. 92mm cable TB was also ordered for it today.
Old Nov 7, 2018 | 08:17 PM
RySmDPT14's Avatar
I just made my own aluminum bing from 3/8 aluminum threaded with npt tap, then welded it to my intake pipe. Most welding shops wouldn’t charge much to weld it on for ya.
Old Nov 9, 2018 | 11:48 AM
TrickTurbo's Avatar
Truck Sponsor
We can build you a throttle body pipe, using 3.5" aluminum with any bung you want to add to it.
Old Nov 9, 2018 | 06:50 PM
MikeGyver's Avatar
I did that, too. The first time. After that I welded a slug of aluminum to the pipe, then drilled and tapped it. Expect to re-tap any threaded fitting that has been welded on.
Old Nov 9, 2018 | 06:53 PM
1FastBrick's Avatar
See! Stand up service right there.
UnrthdxDream
16
Mar 1, 2007 09:33 AM
bluecajun5.3
Mar 12, 2006 03:54 PM
wkdivr
24
Aug 1, 2005 09:50 AM
OLD BULL
Aug 2, 2004 07:22 AM
ThunderZ28
Nov 15, 2003 01:27 PM
