Pictures of Turbo manifold....
Old Mar 16, 2006 | 01:24 AM
  #21
Yellowsierra's Avatar
Originally Posted by Snake Eater
Are you going to use the MAF or run a 2 bar to tune it? 2 bar would probibly be easier to run and run a more steady AF ratio. Plus you will be able to run cool dual intakes too.
How do you run a 2-bar sensor. Do you just buy the sensor and program for it???
Thanks
Old Mar 16, 2006 | 02:32 AM
  #22
TurboGibbs's Avatar
yeah, and to do it right you need the 2 bar tuning option with the hptuners you have.
Old Mar 16, 2006 | 07:18 AM
  #23
FMOS Racing's Avatar
Originally Posted by duwem
nice signature picture......
Thanks! (sorry that took so long)
Old Mar 16, 2006 | 08:26 AM
  #24
Awesome I will have to look into that... So where can you buy a 2-bar sensor?
Old Mar 16, 2006 | 08:41 AM
  #25
TurboGibbs's Avatar
12580698 is a 2 bar map # I got per Zippy. I have yet to use mine though
Old Mar 16, 2006 | 08:46 AM
  #26
Go to a junk yard. ALL the old GM's and even honda's used GM 2 bar map sensors. they are black and like 1" wide and 2" long. Unlike the MAF and 1 bar map on your truck now where you have to tune the VE and PE tables to match what the boost will be as best as possible, the 2 bar map actually accounts for each # of boost and ads fuel accordingly. This is especially good on turbo's because you can have 8# of boost under a load at 2Krpms one minute and 1# of boost at the same RPM the next minute with no load.
Much more acurate AF ratio and much easier to tune.
Old Mar 16, 2006 | 09:01 AM
  #27
If thats the right part# I can get that sensor from GM parts direct for $39.38
Old Mar 16, 2006 | 09:08 AM
  #28
TurboGibbs's Avatar
That is where I ordered it from. I pestered Zippy and others and he confirmed it. I think it is the same one they use on the Saturn with a supercharger (Ion maybe?)
  #29
ColtSteele's Avatar
I'm using a pcm flash for timing and to remove rev and speed limiters, tm and such, and a SMT6 and 2 bar map to do my tuning.
Old Mar 16, 2006 | 09:11 AM
  #30
TurboGibbs's Avatar
SMT6?
English por favor.
