Pics of progress on new intake setup
Old Mar 22, 2006 | 07:05 PM
  #41
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by unklej
Looks great,
Not to hyjack the thread or anything, but do you think this setup with a 90mm tb would work good with a NA setup?
Jeff
Only for a big cube stroker.
Old Mar 22, 2006 | 07:12 PM
  #42
8ALTNG's Avatar
Black- I think that is the type of elbow that a guy on LS1Tech is running. his name is PurEvl. The car is silly
Old Mar 22, 2006 | 07:46 PM
  #43
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So the 4bbl tb would be better than the 105mm accufab tb?
Old Mar 23, 2006 | 01:50 PM
  #44
TURBO8's Avatar
Nice set up! If it was not for my fear of the cops towing my truck away I'd try that as well. If it does not have a carb eo#, (or 50 state legal) your screwed here. Some take the chance, I can't. I am very interested on how it works out.
Old Mar 23, 2006 | 01:52 PM
  #45
TURBO8's Avatar
Originally Posted by 8ALTNG
Curt- Some guys making big power over on LS1Tech saw 70-90+ rwhp, i am looking for a 30-40rwhp gain. But the big thing is that I will now be able to run 20+ psi. I am not sure if Don is doing lines or not. I will ask him when I talk to him.
Why cant you run 20psi? I spiked to 22 on accident!
Old Mar 23, 2006 | 01:59 PM
  #46
1slow01Z71's Avatar
Leaning out #7 is the main reason to be scared of high boost with the truck intake.
Old Mar 23, 2006 | 03:16 PM
  #47
TURBO8's Avatar
Oh, I got it. Thanks
Old Mar 23, 2006 | 03:58 PM
  #48
8ALTNG's Avatar
I have hit higher than that. When my guage broke it went back to zero
Old Mar 23, 2006 | 04:00 PM
  #49
Slowhawk's Avatar
LS1Tech Sponsor
He already spiked and held alot more than 20lbs already when his controller broke. It's not if you hit it,it's if you can consistantly run the high boost
Burning up the rear cylinders has been a long time problem.You just need to be in the FI market to see it alot.We also have seen alot of split cylinders.
Old Mar 23, 2006 | 04:01 PM
  #50
1slow01Z71's Avatar
Damn man what kind of gauge were you using? Hey can you take some more pics specifically of where the cable bracket and all of that is mounted I am most likely going with the accufab 105mm or the 4barrel setup and will need to relocate the brackets.
