Parts list to go along with Turbo Kit
Here is the complete list of items I needed for my turbo build.
I am sure there are parts that you will not need to purchase but I wanted to show you my list to let you know that it gets VERY expensive and to help steer you in the right direction:
ON3 Turbo Kit 76mm
Tial 50mm BOV
Precision 46mm Wastegate
NGK TR6 Spark Plugs
Walbro 255 (2)
80 lb injectors w/adapters (plug and play)
AEM Truboost
6an Fuel/Cooler Lnes (35 ft)
8an fuel lines (20 ft)
A1000 FPR
Aeromotive Billet Fuel Filter
Moroso Oil Catch Can
3 bar map sensor
Isky Triple 12 Cam/Springs
Ebay Pushrods
Lifters
GM LS9 MLS Head Gaskets (2)
Ebay Head Stud Kit
Camaro Dual E-Fans
Nelson Harness (for efan)
Timing Chain
Oil Pump
4l80
Trans Rebuild Kit
4L60 to 4L80 adapter
Fittings for tranny/fuel system
Tru Cool Trans Cooler
Yank Stall
Eagle Detriot Locker w/bearings
Muffler
Custom Built Steel Driveshaft
Rear end/Tranny/Oil/Coolant Fluids
And like Oakley said be prepared to be nickel and dimed for other things that might come up.
Let me know if you have any other questions and good luck!
-BoostedBowTie
ON3 Turbo Kit 76mm
Tial 50mm BOV
NGK TR6 Spark Plugs
Walbro 255 (2)
AEM Truboost
A1000 FPR
3 bar map sensor
Ebay Pushrods
Lifters
Ebay Head Stud Kit
Camaro Dual E-Fans
Timing Chain
Oil Pump
4l80
Trans Rebuild Kit
Yank Stall
Muffler
-BoostedBowTie
-BoostedBowTie
-BoostedBowTie
I do have some questions. I re-organized your list with some headers that correspond to my list and what else I might need. There are some items I am unsure of atm. If necessary or even just a "really good idea" I'd rather do it. In particular those items that will cost more $$ or time later to install.
So Some Questions:
You state the injectors were plug and play. I didn’t realize some weren’t. Is there an easy way to tell?
Anything on the Left off my list, do I need right now that I do?
Included in Turbo Kit (or equivalent):
ON3 Turbo Kit 76mm
Tial 50mm BOV
On my list or equivalent:
Walbro 255 (2)
AEM Truboost
Isky Triple 12 Cam/Springs – although Cam not chosen…
Ebay Head Stud Kit
Left off my list, but I will add:
Muffler
NGK TR6 Spark Plugs
Left off my list, do I need right now?:
A1000 FPR
3 bar map sensor
Ebay Pushrods
Lifters
Camaro Dual E-Fans
Timing Chain
Oil Pump
Doing the trans later when it explodes list:
4l80
Trans Rebuild Kit
Yank Stall
Hadn’t planned on doing:
Starting point is the L94 6.2L Alum (L92 with DOD/VVT)
Yeah, it's the little triangle plastic panel, that covers the side mirror mount basically.
Here's a video with the exact piece I'm talking about. I bought my kit off "REDCYCLE13" this is a video with it in his truck. It won't fit my truck.
Turbo gas towing - YouTube
-Kenny
-Kenny
5.3lSilverado
25
08-29-2016 12:48 AM
