Overheating
Old Jul 14, 2013 | 07:19 PM
  #31
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by 02chevyls1
I have an over heating problem and I can't figure out wtf it is. 370 front mount is the set up 160 stat e fans, fans are dual 12s I have an aftermarket overflow tank. I can only make 2 4-500 foot sand drags before she baries the temp gauge. Or if I'm driving for along time it will run at 180 stop at a sign for awhile temp will be fine then once I take off it will spike then drop back down again. I don't have an oil cooler eather and head gaskets should be good motors one got 1000 miles on it sand drags are 15# and driving normal is none and it only does the stop sign thing sometimes I think it's cursed
Ok just noticed something. Aftermarket over flow tank.
Got any pics? Of this tank and how your coolant hoses are routed.
And what psi cap you have on there.
Could something as simple as a weak cap or hose routing.
  #32
burbalanche's Avatar
been running a 160 stat. in my truck also with no issues either.even in boost i see around 180.havent had any issues yet.my tuner runs 160 stat. in everything also he told me and hes a well rep. tuner to.
Old Jul 15, 2013 | 04:05 AM
  #33
02chevyls1's Avatar
I'm keeping the 160 stat and the tank is mounted on the top of the fan shroud on the passenger side and the hose comes straight out of the bottom and into the radiator and I had a 21# cap now I have a 14# but I don't think there is a noticeable difference. If I lifted a head it should overheat all the shouldn't it?
Old Jul 15, 2013 | 04:16 AM
  #34
02chevyls1's Avatar
With the 34 in radiator can ic piping still be ran between the head lights and radiator or do you have to come up from the bottom
Old Jul 15, 2013 | 05:26 AM
  #35
TrickTurbo's Avatar
Truck Sponsor
Do you have a pic?
Old Jul 15, 2013 | 07:08 AM
  #36
02chevyls1's Avatar
Ill take some after work
Old Jul 15, 2013 | 08:42 AM
  #37
Bama2door's Avatar
I've got a 34" radiators and was able to fun my IC pipes between the headlights.
Old Jul 16, 2013 | 02:05 PM
  #38
gamble686's Avatar
Shouldn't be a problem should be able to route the IC around the 34".
Old Jul 17, 2013 | 04:40 PM
  #39
gamble686's Avatar
So have you made any more changes or seen any more progress?
Old Jul 17, 2013 | 07:42 PM
  #40
Alpinestar's Avatar
Might be a little tighter on an '02 though... I just took my IC piping underneath so I didn't have to cut a bunch of **** up.
