Overheating
Old Jul 13, 2013 | 11:40 AM
TrickTurbo's Avatar
Truck Sponsor
All the time. But you work have to be way off to make that happen.
It seems to be a little here there type of problem.
Racing hot lapping, but then just stop and go stuff.
Are you losing any water volume? Or have ever ran the catch tank low?
Old Jul 13, 2013 | 12:48 PM
02chevyls1's Avatar
Well I did one Dyno run today and it went from 180 to 240 in one run and the guy said it could be timing, but it want the guy who thned it I've never ran a catch tank and I'm pretty sure the olny time I lose water is when it's over heating and comes out the over flow. What pressure radiator cap do I need
Old Jul 13, 2013 | 11:50 PM
gamble686's Avatar
Originally Posted by 02chevyls1
If the timing is off would if make it over heat
Detonation would cause bad overheating for sure.
Old Jul 14, 2013 | 09:36 AM
George C....'s Avatar
Formerly ScreamingL
Tear the heads off and change head gaskets And use studs before you create more issues
Old Jul 14, 2013 | 11:03 AM
02chevyls1's Avatar
Every bolt in the motor is arp and gaskets olny got 1800 miles on them I'd hope they are still good I had this problem sence I put the turbo on
Old Jul 14, 2013 | 01:54 PM
Formerly ScreamingL
Lifted a head or cracked a head
Old Jul 14, 2013 | 02:24 PM
Bad Scuba's Avatar
Registered User
You can't run a 160 deg stat with boost or in a newer chevy there made to run at 195 deg. I tried the same thing and a guy on LS1 Tech site told me to put a 195 deg stat in and when I did it cleared up everything!! My gauge shows 200 before it opens but I think its just my gauge. Anyway it's not getting hot anymore.
Old Jul 14, 2013 | 04:46 PM
Formerly ScreamingL
^^^^^thats complete nonsense...
Old Jul 14, 2013 | 05:03 PM
Bad Scuba's Avatar
Registered User
Nope true fact!! the 160 deg stat will keep opening to soon until the water temp is the same in the motor and radiator after a while the stat will just stay open but the motor and radiator will continue to heat up. Besides what would anybody have to lose by trying it?? $10 for a stat and 10 mins to install it!! Trust me that's what it is. Also if you don't believe me call a parts place and ask them what the temp is on a stat for that model and year.
Old Jul 14, 2013 | 05:40 PM
Formerly ScreamingL
Stats cost more then 10$
Actual experience proves your theory wrong...don't be drinking the kool-aid it will lead you to false theories
