Over Boost???
Well guys i dont know what happen to be making 15 20 lb of boost.
I have a t76mm from trick performance with a 6 lb spring on a 2010 5.3, The truck was working good airfuel at 11.5 timing at 12.
This happen after i install the boost gauge so i start looking for a leak and found it. Its was on the hose that goes to the boost gauge I fix it but it still over boosting.
Today i went under the truck to check the wastegate and found this, I dont know if this is the problem. Theres a crack and theres signs where is leaking where the wastegate sits. Can that make my truck over boost? Or the boost gauge is not working right? I dont want and try a long WOT run to see if my air fuel gauge goes lean, Not trying to blow the motor.
