Ordered a Trick kit
Old Mar 19, 2010 | 06:23 PM
charcold-bowtie's Avatar
if you plan on actually using that 3 bar, i hope you have new injectors, ie not the ones in your sig. I see you said injectors in the original post
Old Mar 20, 2010 | 06:30 AM
brent1976's Avatar
11 Second Club
A shop near here has 65# short ones that are drop in for cheap, that are flow match, so I am going with those. That is where I'm going for my tune also.
Old Mar 20, 2010 | 11:33 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by brent1976
I ordered a front mount kit for my truck. It is an air to air intercooled t76 with 44mm wg. I have a list of stuff I need, what else do I need to have to do this in a weekend.
I have a 3 bar map, injectors, e-fans, iat sensor, anything else?
Thanks Brent, I know you will be happy with the new set up.
Old Mar 26, 2010 | 05:12 PM
brent1976's Avatar
11 Second Club
Alright, I need some help here. Here is a link to the stuff I think I need, tell me if I'm right or not.
3 bar MAP
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_982wt_1167
IAT sensor
http://cgi.ebay.com/ebaymotors/MSD-I...#ht_3040wt_898
Also where is the best deal on 60lb injectors, the shop that everyone around here talks about doesn't have their stuff together, because they can't even figure out what injectors I need, even though I have told them.
Old Mar 26, 2010 | 06:12 PM
smokeshow's Avatar
Mod with training wheels
http://www.diyautotune.com/catalog/f...s-c-52_58.html
Not a bad site for fuel system parts...
Old Apr 4, 2010 | 08:42 PM
brent1976's Avatar
11 Second Club
Updated list
3 bar map, or will a 2.5 bar work with the 3 bar SD OS
iat sensor
egr block off
oil pan gasket
boost gauge sensor
boost controller
I picked up some nice Camaro e-fans, I just need a harness, and I think I am just going to go with SRT10KLLRs 60# injectors, because the local shop doesn't seem to want to put any effort into finding the injectors I need. I have ordered a couple of the things on the list already, but I want a complete list, so the install doesn't take me a month.
Can anyone think of anything else?
Old Apr 5, 2010 | 06:22 AM
zeake's Avatar
Updated list
iat sensor
egr block off
oil pan gasket
boost gauge sensor
boost controller
Why do you need an oil pan gaskit?
Old Apr 5, 2010 | 06:33 AM
brent1976's Avatar
11 Second Club
Mine leaks right above the drain plug, and since I'll have the pan off to put the drain line in, I'm going to put in a new one.
Old Apr 5, 2010 | 06:36 AM
zeake's Avatar
I see. Oil cooler and http://www.lingenfelter.com/mm5/merc...gory_Code=C186
Old Apr 5, 2010 | 07:51 PM
brent1976's Avatar
11 Second Club
Which of these map sensors do I need? I'm pretty sure the 3bar sd os only goes to 2.5 bars so what is the point in having a 3 bar map.
3barhttp://www.diyautotune.com/catalog/m...sor-p-161.html
or 2.5 barhttp://www.diyautotune.com/catalog/m...sor-p-106.html
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Lamartian92
Aug 21, 2015 01:43 PM
MattOKC
Aug 18, 2015 11:30 AM
Jake75
Jul 22, 2015 09:20 PM
