Old Engine Pics
Old Jul 9, 2009 | 08:09 AM
Mort's Avatar
Default Old Engine Pics
In Dec 07, after a good 1/4 on the G-Tech, I discovered I had some blow-by. I did a compression test and all had 130 - 133 psi except #3 was 110 psi. A couple of days later I did a leak down test on #3 but did not bother with the others. I got a reading of 30 psi with 95 psi supplied pressure and the leak was in the crankcase with the air exiting from the pcv in the driver's valve cover.
Last night I pulled the driver's side head after a long time passing. :nunchuk1:
Here are the pics. No damage I can see except for a shiny wear mark where I marked the pic. The mark is less than 3/16" wide and cannot be felt with my finger nail. No sign of any detonation? Broken ring? What do you think?
Attachment 48618
Attachment 48619
Old Jul 9, 2009 | 08:31 AM
ssavalanche's Avatar
I would bet that when you pull that piston out you will see a broken middle ring land. I have seen that too many times. When you take off the rings, parts of the land will fall to the ground.
Old Jul 11, 2009 | 08:24 AM
Mort's Avatar
Thanks for your reply.
Do you happen to know what causes middle ring lands to break?
Old Jul 11, 2009 | 08:49 AM
I have seen many of these broken. Most of these are on boosted engines. I had one happen on my N/A camaro with high compression. Apparently this happens with high cylinder pressures and high cylinder temperature.
Old Jul 11, 2009 | 09:59 AM
Mort's Avatar
Thanks Again!
I may have this engine apart sooner than later.
Old Jul 11, 2009 | 01:34 PM
built408's Avatar
according to your g-tech, how much rwhp do you have?
Old Jul 12, 2009 | 10:58 AM
Mort's Avatar
Since my runs with the G-tech start from a launch the HP calculator does not seem to work properly. Seems like it looses the rpm signal. The last run I did told me I had 415 rwhp at 2485 rpm and that is close to the maximum rpm it recorded for the run. Not sure what is happening to the rpm signal but my Alky Control meth progressive control may be interfering with the signal.
Old Jul 12, 2009 | 11:22 AM
Wilde Racing's Avatar
How do I change this text
yea second ring land is most likely broken...
ARC
57
Feb 21, 2022 10:54 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
USMCvet0311
Sep 30, 2015 10:34 AM
chacho44
Aug 17, 2015 03:36 AM
03sierraslt
Jul 11, 2015 02:47 PM
