Max Lobe speed of TVS1900?
I should be getting my TVS sometime soon, and I'm wanting to shift at around 6100-6200rpm.. I'm just worried the TVS will max out?
I've bought the tvs of MCN5, and installed is a 2.8 pulley.. He's sending me a 3.1 that I should be using intially until I build up my engine...
any ideas of ratio calculations?
any idea what the max would be? Right now I've got my shift points set at 6500rpm, the truck loves pulling all the way up till there.. I was hoping it would with the tvs, but just worried something might go wrong
Spin the szhitz out of it and have fun.. Perhaps someone else who has run boost on a stock bottom end can add some input but I think you'll be fine with the 2.8 pulley and just over 10lbs of boost with the right tune. I didn't tighten the 2.8 up prior to placing it in the box so you'll need to tighten it up if you decide to leave it on there.
