oil getting to hot
Old Mar 15, 2016 | 02:26 PM
  #21
tim wellington's Avatar
Default adapter block
i was talking about block, all my parts came in today except my -8 to -10 adapters ,i going to through it my lift went it home and find a spot to mount close to block as i can . my oil temps were getting up 315 .with 5qt of rottela and 1 quart of lucas .i am now changing oil every 800 to 1000 miles ,cause i know heat if killing oil just hit 10,000 miles on my boosted build ,so that 11 oil changes this WHOLE turbo build is a learning curve. so the next time you future turbo guys here ALL YOU GOT TO DO IS BUY A KIT (THAT WAS I TOLD) TELL TELL TO STOP LYING LOL..................
Old Mar 15, 2016 | 02:38 PM
  #22
25hdtankhauler's Avatar
Registered User
blah blah blah, not useful input.
Sorry guys for the hijack --- Im going out to the shop and mess with my tank hauler. Just got a set of LT's and stainless dual exhaust from Speed Engineering.
Old Mar 15, 2016 | 03:19 PM
  #23
Default ??????
what are you talking about are you lost .READ I STATING THERE IS MORE TO TURBO ING A CAR AND TRUCK THAN PEOPLE EXPECT .REALLY CHECK UR SELF BEFORE POSTING .......//;
Old Mar 15, 2016 | 03:34 PM
  #24
Atomic's Avatar
I have a gauge for that
25hdtankhauler and hondarider552, That's enough of the bad mouthing each other. If you want to continue then take it to PM. You both had your thoughts in but there is not any more useful content to be had in this thread by debating who knows the duramax better. This thread is for gas turbo oil temperatures.
Tim, no kidding. It cracks me up the guys that want to turbo a gas truck "on a budget". Just go ahead and double that might get you close.
Old Mar 15, 2016 | 03:40 PM
  #25
lxcoupe's Avatar
Wiser words have never been spoken.
Old Mar 15, 2016 | 04:48 PM
  #26
GMCtrk's Avatar
Just run oil designed for high temp turbo apps. I've never concerned myself with oil temps.
Old Mar 15, 2016 | 04:52 PM
  #27
lxcoupe's Avatar
Do you run VR1 20/50?
Old Mar 15, 2016 | 05:13 PM
  #28
Default temputre oil
I though rottella was high temp oil
Old Mar 18, 2016 | 08:58 AM
  #29
Default oil cooler
derale 15800 did it job temp drop 85degress ,DOWN FALL .NOW it takes oil pressure about 8 seconds to show up on cold starts. is this a common thing also lost 4psi idling
Old Mar 18, 2016 | 09:15 AM
  #30
madmann26's Avatar
You've introduced a new variable into the system. The pump has to pump harder and probably pumping a little more oil.
8sec?
I can see that. It probably has to build the pressure up in the system and build it so the oil pressure sending unit sees it. It could be it just takes that long for the pressure to build at the sending unit.
