oil getting to hot
Old Mar 11, 2016 | 05:09 PM
Y2KLimited's Avatar
Originally Posted by lxcoupe
I use a large Derale cooler up front and most importantly for a street car, a thermostat from Improved Racing to make sure the oil gets up to 180 degrees. The tstat block adapter is a bit pricey but imo if a factory truck has an oil cooler then a turbo truck absolutely needs one. If you've ever driven a C5 Z06 with even a stock motor (they did not come with an oil cooler) and beaten on it you'll see the oil temps rise to the mid 200s real real quick.
lol my sts turbo car with a forged 346 would hit 300 oil temps on 30 minute track sessions, about 10 minutes in....with a larger dewitts radiator....and 15w50 mobil.
Old Mar 11, 2016 | 07:04 PM
25hdtankhauler's Avatar
Registered User
Use a fan cooled cooler wired to 220 oil t stat. My LQ9 oil temps would get up to 260/300 pending on ambient temps pulling long grades with heavy loads. I machined a 2x2 cube of aluminum for t stat and oil lines. Installed it in oil supply line to turbo. Temps never went over 230.
Old Mar 11, 2016 | 07:36 PM
hondarider552's Avatar
Bought the ligenfelter oil adapter for my LY6 going to run a cooler to the front of the bed with fan.
Old Mar 11, 2016 | 07:37 PM
Originally Posted by 25hdtankhauler
The first duramax block was redesigned due to low oil temps. Lube galleries in block and heads where decreased .065 smaller. If you gm super diesel builders look up some of this data you can add miles to the brute and save $ on mods.
Not sure where your getting your info from but the duramax never had a problem with low engine oil temps... in fact it has the opposite. That engine needs better engine oil cooling when towing heavy.
Old Mar 11, 2016 | 07:44 PM
Registered User
The prototype did.. Never made it to the market. And you are correct... They addressed oil galley issue but change turbo and head cooling galley. Had a big problem splitting head caskets and burning injector tips first two years of market production.
Old Mar 11, 2016 | 07:48 PM
Registered User
Inside info... My son retired from GM after 42yrs as a mechanical engineer.
Old Mar 14, 2016 | 06:20 PM
Blah blah blah off topic, disregard this post.
Old Mar 15, 2016 | 01:15 PM
tim wellington's Avatar
Default adapter block
anybody bought an adapter block to feed to -8 lines to cooler its doesn't matter if i turn it upside down since i mounting cooler in front of bed does it ?
Old Mar 15, 2016 | 01:20 PM
Atomic's Avatar
I have a gauge for that
No it shouldn't matter. If you are 4wd it will hit the driveshaft though.
lxcoupe's Avatar
I think this is two separate questions? The oil cooler can be mounted vertically or horizontally, with the inlets and outlets facing up or down. Most front mounted oil cooler setups have 5-7ft minimum of line going to and from the cooler. If you comb the vette forums in the autocross / road racing section, some of the guys have data logged pressure drops before and after adding a cooler and found drops to be negligible. Depending on how far back in the bed you plan to mount the cooler, the mileage of the motor in consideration, and whether or not you've replaced the oil pump, it might behoove you to use a medium volume pump from Melling if the lines going to the cooler are going to be really long.
