Oil feed and return lines??
Old Mar 15, 2014 | 05:19 PM
  #21
timmay208's Avatar
Originally Posted by darnie
what would be easyer to remove on the 4x4 timing cover or the oil pan?
ive been trying to figure this out to. cause no way im going to tap a pan with it on the motor
Old Mar 15, 2014 | 08:19 PM
  #22
BUTTERB30's Avatar
THIS MAY or may not help you lol and yea dont tap it on the truck oh my find my thread on that recent ordeal i went thru lol
https://www.youtube.com/watch?v=g1e3kx3mOMY
Old Mar 15, 2014 | 08:43 PM
  #23
timmay208's Avatar
seems like tons of fun... NOT
Old Mar 16, 2014 | 08:49 AM
  #24
GRRR65GTO's Avatar
I tapped my oil pan with it all bolted up on my 4x4 truck but I did it on the front. So if any shavings get in there you can get some grease on your finger and get them out cause the bottom of the pan is right there. I was also able to hold a vacuum right next to the bit and that sucked up most of them.
Old Mar 16, 2014 | 11:46 AM
  #25
timmay208's Avatar
Ill spend 8hrs doing it right before ever tapping a pan on the vehicle
Old Mar 17, 2014 | 01:45 PM
  #26
WJ MARK's Avatar
I tapped mine with the pan on 8 years ago and no issues. I would also use Trick's oil adapter. Its the best one out there!
Old Mar 17, 2014 | 01:55 PM
  #27
boostedsl2's Avatar
I like to use sandwich adapters for the feed. I usually have gauges and other things that need oil pressure too.
Here's a cheap glow shift one that works (GlowShift Oil Filter Sandwich Adapter - 13/16-16 Thread)
Robot Check
I'm guessing that most don't have 1/2" NPT taps and the drill bit to go along with it. Usually its cheaper to pull the pan, drill a 1/2" hole and have a 1/2" NPT bung (or 10 AN) welded to the pan.
Cheapest way to do it is buy a Aluminum half union from mcmaster carr and go to a welding shop before their lunch time. Usually a welder will tig up something like that for $5.
Low-Pressure Aluminum Threaded Pipe Fitting - 1/2 Pipe Size, Half Coupling - 44705K319 - $1.82/each
http://www.mcmaster.com/#44705k319/=r4wm56
Pretty sure you can't T the pressure sensor on the block very easy. I think its a metric straight o-ring fitting. You could probably find the fitting but it would cost you $100 lol.
Old Mar 17, 2014 | 09:09 PM
  #28
cpolaris502's Avatar
Robot Check
Cool, thanks for noticing my post, lol. I will most likely end up doing an adapter at the oil filter with a thermostat a cooler. Turns out my 5.3 friend did this and not T-ing from the sender.
Old Mar 17, 2014 | 10:06 PM
  #29
Atomic's Avatar
I have a gauge for that
Those sandwhich adapters will not work on a 4wd, for future reference. Been there done that.
Old Mar 18, 2014 | 01:42 AM
  #30
idahoblkss's Avatar
Tapped mine with it still on the motor. Just use grease and go slow the drill bit will pull the shavings out naturally. I also used tricks oil adaptor and I'm awd for the record and it worked good.
