Oil feed restrictor
Old Aug 6, 2007 | 03:03 PM
thunder550's Avatar
High on diesel fumes
Default Oil feed restrictor
What are you turbo guys running for oil restrictors?
Old Aug 6, 2007 | 03:07 PM
350SS's Avatar
I haven't done this yet, but need to. Alot of guys are either running nitrous jets or the function7 setup. You've probably already seen this, but just in case you haven't:
https://ls1tech.com/forums/showthread.php?t=569238
Old Aug 6, 2007 | 04:16 PM
quicksilverado's Avatar
I am using the function 7 on my truck.
Old Aug 6, 2007 | 05:14 PM
kbracing96's Avatar
I made a .075 restrictor for mine.
Old Aug 6, 2007 | 05:22 PM
thunder550's Avatar
Where did you put it?
Old Aug 6, 2007 | 05:33 PM
vanillagorilla's Avatar
I'm still running whatever is in the STS kit still. Is that bad?
Old Aug 6, 2007 | 05:34 PM
kbracing96's Avatar
I still have the check valve from the sts on the turbo, so I took a brass 1/8 NPT close nipple and filled it about 1/3 full of soder and drilled it out with a .075 drill bit. Then I put it between the check valve and the -4 inlet fitting on the turbo, using a 1/8 NPT coupler too. I would have used a N02 jet, but this was faster as I don't have a place around here to buy them.
Old Aug 6, 2007 | 08:13 PM
I have told a few people to do that. Seems like the easiest way to do it.
Just braze the brass fitting closed and drill a smaller hole.
Old Aug 6, 2007 | 08:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
We use Nitrous jets. Choosing the right size can take time.The correct way is to put a oil pressure gauge at the turbo and get the recommended pressure which is ussually 30-35psi. I just go by the oil smoke out the exhaust. Ussually end up with a .051 to .072 depending on oil pressure at the engine.
Old Aug 6, 2007 | 08:34 PM
parish8's Avatar
single digit dreamer
we did the nitrous jet trick. started with .075 and still got smoke se we steped down to the next size. something like .69 but i am not sure of that.
