Oil Everywhere
Old Jan 18, 2006 | 07:29 PM
  #21
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by TurboBerserker
No need to carry a relay... if it fails just jump the wires on the air pump all to the same post. That puts the pump into full time high speed mode and bypasses the relay altogether.
COOL,can you draw a simple picture for a simple person like me?! BTW, DAVE SOUTH IS AWESOME, it seems like he goes the extra mile to help, sts cust serv and shipping has come a long way thanks to him, credit where credit is due.
Old Jan 19, 2006 | 12:40 AM
  #22
JOHN1L40's Avatar
Default Parking on incline..
I found that if you park on an incline, with the nose UP, oil will drain into the turbo and eventually cause all kinds of smoke and oil in the intake. The only solution Ive come up with is to park nose down... I also went with the high volume oil pump because the stock one that came with the kit would sound the buzzer all the time under heavy boost. No problems with the HV pump..
Old Jan 19, 2006 | 06:22 AM
  #23
Avsfan's Avatar
Originally Posted by TG02Z71
My pump makes loud buzzing noises when the oil is cold and relatively quiet otherwise.
Dave is the best, I must add as well. He has helped me out about a dozen times!!
Yea Dave's a hell of a guy. Mine is pretty noisy when it's cold too and quiets down once it warms up. I was told that is the norm.
Old Jan 19, 2006 | 06:25 AM
  #24
Avsfan's Avatar
They have an anti-surge valve that should take care of that problem. Had mine installed a while back, but haven't put it through parking uphill,nose up test yet.Hey John do you have a pic of your relocation filter in the bed???
Old Jan 19, 2006 | 06:46 AM
  #25
TIM Z's Avatar
11 sec. Truck Mod
where did you get the h d oil pump? just would like to have a backup.
Old Jan 19, 2006 | 09:32 AM
  #26
Mort's Avatar
Cool
The oil inlet to the turbo center housing has an inline fitting with low pressure flow control valve. When the engine is off and the oil pressure goes down the valve closes and stops the flow of oil into the turbo housing. Mine used to leak on the garage floor overnight until I replaced that fitting. So far no more oil leakage. Thanks Dave.
Old Jan 20, 2006 | 12:02 AM
  #27
JOHN1L40's Avatar
STS swapped it out for me. They said it was for a higher HP application thwn mine. It is a little noisier than the stock one but works good.
As far as the oil running backwards when parked nose up, The oil is comming from the 2 ft of return line between the pump and the turbo. My pump is a little lower than the turbo, but not much. I gueass if you have enough drop to the pump you wont have this issue.
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
