NPG-R coolant for boosted aps.
Old Jun 26, 2008 | 01:25 PM
sharpshooter's Avatar
Default NPG-R coolant for boosted aps.
Would this coolant be any benefit for boosted aps over Dexcool?It seems a lot of people are starting to think we loose cylinder #7 because of heat.
Old Jun 26, 2008 | 10:20 PM
I used it for quite awhile and works great, but if you happen to blow a radiator hose or end up with a leak and you don't have extra with you your done because it doesn't mix with any other solution.
Old Jun 26, 2008 | 10:38 PM
04Denali's Avatar
very true but it is also a no - to low pressure system, driving my truck in 107* over 200* coolant and you can just open the radiator cap,
so you have less of a chance for your hoses to get holes in them because they are under less than 2psi of pressure, usually zero to 1 psi
6.0l RST
Nov 23, 2015 11:30 AM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
