NPG-R coolant for boosted aps.
Would this coolant be any benefit for boosted aps over Dexcool?It seems a lot of people are starting to think we loose cylinder #7 because of heat.
I used it for quite awhile and works great, but if you happen to blow a radiator hose or end up with a leak and you don't have extra with you your done because it doesn't mix with any other solution.
so you have less of a chance for your hoses to get holes in them because they are under less than 2psi of pressure, usually zero to 1 psi
06murder
Sep 4, 2015 03:54 PM
