Not enough injector for the ProCharger...
Adkoonerstrator
Originally Posted by PappyDan
a after market regulator and a good set of 42 lbs injectors can make a world of difference.
so far every book I have read on moding our motors with a turbo or a supercharger.
2 things remained constant a regulator to set the fuel pressure to 80 psi and a set of 42 lbs injectors.
should be getting a Walbro 340 high pressure installed this weekend...hope that cures it...plan on running it alone w/o the ProCharger supplied in-line...
I have had one of them fail already and I just have a feeling that this one is contributing to this issue, as well as the stock in-tank...
Adkoonerstrator
I have used the in lines in the past and if they are going bad they are a MAJOR restriction.
A good walboro in tank will take you a lot higher than you're at now, so that will be nice.
last time I checked fp, it was 50#'s @ idle...haven't checked it @ wot on current set-up...what's ironic is that the rpm level I was maxxing old injectors at is about the same level I am now starting to get kr that rises quickly...
didn't get it installed this weekend...hopefully this week w/ cablebandit's anticipated help again...
new Walbro and some race fuel should let us know if it is false knock...
been rained out last couple of days...should get the Walbro in tomorrow...any need in wiring upgrades?
also...anything I can do to correct the fluctuating fuel level while I have the tank dropped?
