no boost and other good news
Old Apr 2, 2007 | 07:12 PM
  #31
MikeGyver's Avatar
If you could relocate the idler pulleys above the blower pulley, and put a smooth pully on the blower, it would turn the other way then. The belt would be routed over, under, and over instead of under, over, and under. I know, it would slip, but it would reverse the the blower.
Old Apr 2, 2007 | 07:23 PM
  #32
Any body with any pics of that? At least scratchin my head will be a great vacation for me nuts.
Old Apr 3, 2007 | 12:01 AM
  #33
PappyDan's Avatar
Tribe Shaman
Well, if you want to run it that bad.
I don't believe I am going to say this.
If the bolt holes will line up, take the head unit off and flip it so the pulleys face the fire wall.
Pull one of the bolts, go to home depot and get a set of much longer blots.
some pipe couplers that the new bolts can fit through and allot of washers
To be used as shims.
Slide the new bolts in the bracket from the back side.
slide a coupler on each bolt, use the washers to shim out the head unit
until the pulleys line up.
if it works right, the red 90 may be all you need to make a connection
from the scroll to the throttle body.
Old Apr 3, 2007 | 07:37 AM
  #34
I was laying there in bed last night around midnight nameing my unborn children and in my head I seen what mikegyver was talkin about and that seems possible. I'd have to fab up a horse shoe type bracket but it might work. I might also look into switching the blower around like pappydan suggests. The only problem with that I could see is it might not be properly supported.
Old Apr 3, 2007 | 01:04 PM
  #35
duwem's Avatar
or, you could sell it and get the right one...or is it too late for that?
Old Apr 3, 2007 | 01:57 PM
  #36
MikeGyver's Avatar
I downloaded this picture directly from my brain. Yes, I see the world in line drawings and people as stick figures. This just represents the belt path that I was trying to describe.
Click to enlarge.
Old Apr 3, 2007 | 08:45 PM
  #37
Click to enlarge.
Thats what I seen last night, No I could sell It, take a loss and go turbo and have way more power.
Old Apr 3, 2007 | 08:51 PM
  #38
1SlowHoe's Avatar
Destroyer of Transmissions
Looks like a 6th grader drew some ***** and a pecker.
Old Apr 3, 2007 | 09:25 PM
  #39
MikeGyver's Avatar
I was laying there in bed last night around midnight...in my head I seen what mikegyver was talkin about and...
Thats what I seen last night...
I couldn't stop myself, I had to quote you...
Old Apr 3, 2007 | 11:27 PM
  #40
PappyDan's Avatar
Tribe Shaman
you can always build some kind of support system.
mike i thought you could draw better then that.
