No AWD dyno- HP estimates?
I'll have to back track a little bit on chassis numbers. Might not quite be 6XX at the rear wheels with current setup... I was thinking of the LS9s peak power as a starting point, rather than the ZL1s, and if actually measured on a AWD chassis dyno you'd lose a couple more % in parasitic losses. But high 5XXs easy, and over 6XX with a larger lower pulley.
You should be okay on the injector side if set to 58psi @ idle, and boost-referenced.
I understand they claim 1k crank for that 525 so maybe 7-750 whp on E for 2wd. You should be ok a little either side of 600 with E85 on AWD. You could always blend 93 for a 50 - 60% mix when you fill up if you have to. Just x gallons of this and x gallons of that it's that simple. There is not much gain after that % anyway and it gives your fuel system more head room. Very nice build!
Lol understood. For where you are starting should be just fine.
Party pulley = give it all the beans max charger rpm (smallest charger and overdriven crank). If you can get a 10% over crank damper (Innovators West or ATI) do so as that helps out with getting to small pulley on the charger that could lead to belt slip. The more surface area that belt grips the better off you are.
The injectors were something I was sort of wondering about, but I have to start somewhere with getting the setup dialed in while not getting kicked out of the house for overspending hahaha
when you say party pulley, which one is that? I have all sorts of interest in more power! I just want to also be able to stomp some hemis while I’m at it. Or at least off the line!
GMNUT
May 10, 2018 12:56 AM
