No AWD dyno- HP estimates?
Hey guys- I am finishing up my build on my 2013 Escalade. I looked through threads and my eyes are blurry from reading all the builds. Curious if anyone has a setup similar to mine and what their numbers are- OR any educated estimates on what I may be looking at. Thanks!
6.2 with the LSA blower with ZL1 brick and heat exchanger 2.55 Lingenfelter Pulley(around 10psi) walbro 525lph in tank pump Boost ref regulator set to 60psi 850cc injectors LSA fuel rail 4” cold air intake -8an feed line with factory feed used for return (this is a deadhead system) -TSP 1 7/8 Longtubes -TSP L92 Stage 1 VVT-1 Camshaft: 216/229, .600/.600, 114 LSA 107 ICL -Texas Speed 7.40 Chromoly Pushrod - Texas Speed Polished .660" Dual Valve Spring Kit :160 lb. @ 1.80", 415 lb. @ 1.15", CB @ 1.015" W/ Titanium Retainers -CompCams Cam Phaser Limiter Kit - LS7 GM Lifters -DOD Delete -MSD Super Conductor wires -Running on E85 let me know what you guys think! |
Do you have access to your tune? If you can post how much fuel it is commanding then you can get an idea on the power it should be making.
Originally Posted by wretched73
(Post 5506938)
If you have HP tuners here is how you use the scanner. I wouldn't swear by these numbers though
(Post 5506938)
I will check out the video to see what I may have been making before the addition of the cam and e85 and such, and get an idea of the gains. I use hptuners so can check my previous logs. Is there ANY accuracy to the channel that shows “hp” or “torque”? I am sure it’s not but was wondering what those actually represent. |
Originally Posted by dantheman1540
(Post 5506941)
Is there a formula for this? I've heard it mentioned in the past but have never seen any data or anything to base the guesstimation on.
It is not exact due to all the variables, but it should give you enough of a ball park. We used this formula for my buddy's turbo LT1 with a holley terminator. The dyno we put it on is a Dyno Dynamics unit which are notorious for producing HP numbers 10-15% lower than a mustang dyno |
Well thought out combination. Should be an absolute beast right off idle and up. I wouldn't get too hung up on peak power. Your area under the curve is going to get thing moving quickly. Although I wouldn't be surprised if the first number registered on a chassis roll started with 6XX.
Nice combo, the cam reminds me of the Thunder Racing LS2 Cheater I had. I'm not up on what the 525 supports but those 850's will probably get stretched out on E in a hurry (80% DC+).
LSA is rated at 556 (9psi) from the factory for reference, so you've added a little more camshaft, good exhaust, and supporting mods. I'd guess you'll crest the 5xx awhp at current psi and have to put the party pulley on it to get to 6xx. Weight vs mph will give you a much closer idea once you are ready. Should put a smile on your face driving though! |
Originally Posted by 68Formula
(Post 5506955)
Originally Posted by ALL ULL C
(Post 5506961)
LSA is rated at 556 (9psi) from the factory for reference, so you've added a little more camshaft, good exhaust, and supporting mods. I'd guess you'll crest the 5xx awhp at current psi and have to put the party pulley on it to get to 6xx. Weight vs mph will give you a much closer idea once you are ready. Should put a smile on your face driving though! when you say party pulley, which one is that? I have all sorts of interest in more power! I just want to also be able to stomp some hemis while I’m at it. Or at least off the line! |
