Nitrous or meth with turbo???
Old Mar 16, 2009 | 07:16 AM
05crew's Avatar
Default Nitrous or meth with turbo???
i have had meth on a STS kit that i had. it work well but i had to fill up the tank all the time. the radix meth kit i did not like so much, did not see good gains and it was way to rich for the setup and hard to tune.
i have a wet kit that im runing now and as of this week i will be the new owner for a KB turbo kit, do i just put the nitrous kit on there for a little kick. or get meth one more time.
Old Mar 16, 2009 | 10:14 AM
05crew's Avatar
what yall think. i know someone has been down the same road....
Old Mar 16, 2009 | 10:33 AM
white lightning SS's Avatar
Depending on your boost level you can run both. Meth for added timing and nitrous for cooling and denser air charge. Either way you will need to retune.
Old Mar 16, 2009 | 01:23 PM
05crew's Avatar
i want to run one or the outher... just to cool the air...i think meth will be better for the street. thanks
Old Mar 16, 2009 | 01:55 PM
WJ MARK's Avatar
im running both. I have not retuned for either. Why the retune???
Old Mar 16, 2009 | 03:49 PM
You cannot possibly be taking full advantage of the adders without a retune. You should be able to run more timing and if tour spraying a wet kit and meth I would think your at least 17-20% too rich up top. I had to remove 17% of wot fuel fo rmeth and I added 6 degrees more timing.
Old Mar 17, 2009 | 09:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
That's a lot of WOT timing...
Old Mar 17, 2009 | 11:48 AM
WJ MARK's Avatar
I was only really spraying alot of meth when I maxed my 42's and ran more timing, Ive since jetted the meth down with less boost and larger injectors. I will probably only use it when upping the boost.
Old Mar 17, 2009 | 12:36 PM
23 degrees WOT with my meth properly tuned, no knock retard.
Old Mar 17, 2009 | 03:43 PM
Hunt&Fisherator
Aaahhh, 23 isn't bad if you have knock and fueling in check . Bet it runs good!!
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
WICK3DxGATA
Aug 31, 2015 07:21 AM
89sierra
Aug 19, 2015 07:13 PM
tim wellington
Jul 31, 2015 03:28 PM
