New turbo manifold in Trick kits.
Old Feb 17, 2013 | 07:43 PM
  #41
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Im in no big hurry so I can wait. I just really like your new cast manifold and the one piece downpipe design. Very clean looking setup.
Old Feb 17, 2013 | 07:50 PM
  #42
TrickTurbo's Avatar
Truck Sponsor
The 3.5 will be a 2 pc design. Easy fit higher flowing no cut and welding ony part. That's a plus. Just add a band clamp in the middle. .
Should have them done in a few weeks.
Old Feb 17, 2013 | 10:59 PM
  #43
dimetweaker's Avatar
Do you have any idea how the crossover flange inlet on the back side lands in comparison to a stock truck manifold outlet ( closer to the block, farther, shorter distance from the back cylinder or closer etc... ) ? I am installing a LS3 into a 63 nova with an aftermarket front clip on it, and I would like to see if I can get a stock truck manifold on the passenger side to see if I should even bother trying to order one of these to fit it up. I will have the motor in the car next week and can try to fit my stock passenger manifold then. Also, will you still offer your last generation manifolds if I want to buy one that I can cut and modify if I have to?
Old Feb 18, 2013 | 09:40 AM
  #44
TrickTurbo's Avatar
Truck Sponsor
Sorry no real comparison. I can take some pics for you of the turbo manifold.
Old Feb 18, 2013 | 10:43 AM
  #45
supercharged680's Avatar
someone is ordering a kit very soon
Old Feb 18, 2013 | 09:22 PM
  #46
98tdi's Avatar
Very slick trick!!
Old Feb 20, 2013 | 08:50 PM
  #47
TrickTurbo's Avatar
Truck Sponsor
Great to read .
Originally Posted by 98tdi
Very slick trick!!
Thanks.
Old Feb 20, 2013 | 09:42 PM
  #48
Gus 82's Avatar
Looks good I may just do this instead of fabbing up my own front crossover setup. Will the crossover fit a NNBS 4x4? What are guys doing for the upstream O2S? If I understood right you are offering turbo manifold, cross over and down pipe for 1500? Looking forward to more pictures
Old Feb 20, 2013 | 09:51 PM
  #49
TrickTurbo's Avatar
Truck Sponsor
Fits 4x4 fine.
Up stream o2?
Yes 1500.00 plus freight.
Should have some more pics up soon.
Old Feb 20, 2013 | 10:01 PM
  #50
Gus 82's Avatar
I have a mail order tune so I wasnt sure if they use Narrow band oxygen sensors on a turbo setup and if your kit had a provision for them. From your answer I am guessing they are done away with like the downs stream o2 sensors when I installed my long tubes.
