New turbo manifold in Trick kits.
Old Feb 14, 2013 | 02:06 PM
  #31
M&M Turbochargers's Avatar
Looks Good Guys!!!!!!
Old Feb 14, 2013 | 04:45 PM
  #32
TURBHOE's Avatar
How thick are the runners and main tube?
Old Feb 14, 2013 | 05:16 PM
  #33
sand man's Avatar
looking good Rick
I'd love to have one the next year
Old Feb 14, 2013 | 09:55 PM
  #34
foose04's Avatar
Pretty Trick piece Trick, I like her.
Old Feb 14, 2013 | 11:12 PM
  #35
silverado2000's Avatar
damn looks like i got my kit 1 month to early.
Old Feb 17, 2013 | 04:35 PM
  #36
TrickTurbo's Avatar
Truck Sponsor
Thinest area is specd to be .187 thick.
Flanges are 3/8 min.
Posting more pics soon.
Old Feb 17, 2013 | 06:56 PM
  #37
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How much are we looking at for the hotside? Also what size is the WG opening? Id want to run a 60mm gate to keep boost low for towing.
Old Feb 17, 2013 | 07:10 PM
  #38
TrickTurbo's Avatar
Truck Sponsor
Normally 1600.00.
But I can do a set for 1500.00 and free freight. .
These would be our stage 4 pipes.
3" down pipe fits the most turbos that use a 3" vband.
The gate hole in the manifold is 40mm.
The only reason to run a 60 gate is large cubes and low boost.
What turbo are you using?
Old Feb 17, 2013 | 07:25 PM
  #39
1slow01Z71's Avatar
Just in the planning stages at the moment. Ive been told an S475 would fit the bill for what Im wanting to do and itll be on a heads and cam L76. I tow heavy from time to time so I want a gate big enough to stay down around 5#s. Do you have one piece DPs in 3.5"? I see on your site that the stage 5 has a two piece 3.5" but didnt know if that pic is out of date since you have so many new goodies coming out.
Old Feb 17, 2013 | 07:33 PM
  #40
TrickTurbo's Avatar
Truck Sponsor
The 3.5" was a welded several sections. Then cut into 2 pc. So it's easier to install.
The new 3.5" dp. Will bearded bent 2 pc design. Noire cutting and welding pre bends.
The 3.5" set does cost more. Not solid on the final price yet.
The lower psi won't be a problem.
You max setting will still get set by the gates spring.
