New turbo manifold in Trick kits.
#43
Do you have any idea how the crossover flange inlet on the back side lands in comparison to a stock truck manifold outlet ( closer to the block, farther, shorter distance from the back cylinder or closer etc... ) ? I am installing a LS3 into a 63 nova with an aftermarket front clip on it, and I would like to see if I can get a stock truck manifold on the passenger side to see if I should even bother trying to order one of these to fit it up. I will have the motor in the car next week and can try to fit my stock passenger manifold then. Also, will you still offer your last generation manifolds if I want to buy one that I can cut and modify if I have to?
#48
Looks good I may just do this instead of fabbing up my own front crossover setup. Will the crossover fit a NNBS 4x4? What are guys doing for the upstream O2S? If I understood right you are offering turbo manifold, cross over and down pipe for 1500? Looking forward to more pictures
#50
I have a mail order tune so I wasnt sure if they use Narrow band oxygen sensors on a turbo setup and if your kit had a provision for them. From your answer I am guessing they are done away with like the downs stream o2 sensors when I installed my long tubes.
