New Set up - what do you think
Old May 10, 2010 | 07:52 PM
tarinitup's Avatar
9 Second Truck Club
Default New Set up - what do you think
My 408 is at the machine shop and I am having the rings gapped for boost and adding patriot stage 3 LQ9 heads. Also the drivetrain will be transplanted into my 04 regular cab. My new compression will be around 9.8 and I plan to run 15lbs of boost with pump gas and meth. A couple of things that are up in the air is the throttle body and intake set up. I have a vic jr. and 90mm cable throttle body that I can no longer use cause of DBW. Should I just stick a stock throttle body on the vic jr. or use a stock intake?
How much power should it make if it made 750rwhp on 15 lbs with stock heads and 9.5 compression?
Should I run 3.73 gears of 3.42 gears? My tire height is 29.5
Old May 10, 2010 | 08:17 PM
skeet's Avatar
i'd stick a 90mm DBW on the vic jr?
whatever you decide its gonna be sick!!! specially in the rcsb
Old May 10, 2010 | 08:37 PM
LsxCody's Avatar
Damn. Everyone is getting a rcsb now
Old May 10, 2010 | 08:40 PM
TIM Z's Avatar
11 sec. Truck Mod
Couldnt you use a TBSS 90mm DBW TB ?
Old May 10, 2010 | 09:19 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I might be interested in your cable 90mm
Id imagine with that CR and better breathing along with less weight it ought to get a little better mileage than your old setup and probably a bit stouter.
Old May 10, 2010 | 09:56 PM
tarinitup's Avatar
9 Second Truck Club
The cable 90mm is sold. If I don't need a 90mm DBW i would like to use stock. I read somewhere that you need a Dr. X harness to get a 90mm to work properly.
I'm hoping for 10's all day long and maybe a 9sec pass with racegas if I decide to push it.
Old May 10, 2010 | 10:01 PM
charcold-bowtie's Avatar
from the people ive seen with real posts, the stock intake will be enought, thats what im gonna use and i plan on 800+
Old May 10, 2010 | 11:10 PM
WJ MARK's Avatar
un the vic. jr. and a 90mm dbw. I just like the looks of the Vic. jr. intake, just makes the engine look faster, LOL.
Old May 11, 2010 | 12:10 AM
Most Hated's Avatar
sick setup bro gl on ur setup
Old May 11, 2010 | 10:08 PM
tarinitup's Avatar
9 Second Truck Club
Would there be any loss going to an ls6 or truck intake from the vic jr? I want my next set up to look much cleaner.
