NEW Front Mount, guaging interest
Old Dec 10, 2007 | 04:24 PM
  #31
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by TurboBerserker
The theory behind it says this should be somewhere 'in between' on the continuum between spool up efficiency and reduced heat.
Seems to me this setup would be better actually. There is less hot side pipe getting to the turbo and stock manifolds are used which retain heat very well. I'd think with the exhaust only having to run downhill and not uphill to get to the turbo it might help too(minor but, hey) Both banks run directly into the turbo instead of one running into the other than to the turbo. On the exhaust side there is less pipe and no sharp bends directly off the exhaust housing.
All those things seems like advantages to me.
Old Dec 10, 2007 | 04:30 PM
  #32
TrickTurbo's Avatar
Truck Sponsor
Ok been working on the NON crush set ups for LOWrides. And to tell you truth, blaaaa. I just do not like the way it turned out, and find it hard to sell to someone LOL. So here is the fix for that type of truck, if you find yourself bahaing your lower truck .
1PC of 3x3 thick wall square tubing about 12-14" or so. Bolt that to your crossmember, and no worries about crushing anything.
Old Dec 10, 2007 | 04:52 PM
  #33
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Goof. Heat on the intake side and of the turbo itself
But what you said is right -- the temp of the exhaust gas would be higher with this kit -- so better spooling.
Old Dec 11, 2007 | 03:43 AM
  #34
Spoolin's Avatar
GFYS and STFU
... 2 u Rick
Old Dec 11, 2007 | 07:35 PM
  #35
TURBHOE's Avatar
Old Dec 11, 2007 | 09:52 PM
  #36
raisinkane's Avatar
Looks great, nice and simple...clean
Good for the warmer climates.
In eastern Canada, the winter, the slush, the salt!! The air filter would not stand a chance...oh well
Old Dec 11, 2007 | 11:01 PM
  #37
WJ MARK's Avatar
Thats why he also has the frontmount thats under the hood.
Old Dec 12, 2007 | 11:38 PM
  #38
raisinkane's Avatar
Nah...I like this new model...
..guess I'll just have to move
Old Dec 12, 2007 | 11:40 PM
  #39
TrickTurbo's Avatar
Truck Sponsor
naw just need the hi mount air filter relocation kit, no worries about water, now salt.
Old Dec 13, 2007 | 09:22 AM
  #40
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by kbracing96
That's an interesting way to do it on a 2wd, but won't work on a 4x4, unless you drill a big hole though the turbo for the torsion bar to go though, . Would make for quick installs too.
Not sure but it might work on the 4x4. The pics make it look like the turbo is against the frame and low. I looked at some old 2500 pics with torision bar, and bar looks like it will be below the turbo.
Here are some more of the layout.
3" Turbo Inlet piping.
gate, final run the gate might be hanging off of DP for better clearancing and more ease in tranny pan removal. This is one of those things you just donot if you like the location until you built it. So we will be building another DP or SP and remounting gate and taking another look. Things like this always seems to give delays but the end product is worth the wait, I beleive.
Exhaust
Inlet to the Intercooler
pic of anti_crushtubing.
