New build looking for 1200hp plus
Hello everyone I am hoping to finish this build and hopefully this one will reach my goals. I tried this a couple years ago with an engine I’ve picked up from a builder in Arizona and turns out it was not quite up to snuff and a few things were exaggerated. So try not to make the same mistakes twice I decided to build it for myself I ended up putting together a LS1 block With some LS3 heads ... I hope I can get a little input in case I am forgetting something that I need. This is my second Procharger build for my 2003 Chevy Silverado
2005. Lq4 408
Manley forged pistons 4.030
Eagle Forged Rods 4340 ARP 2000 7/16
ARP 234-5608 Main bolts
Lunati 4.000 24T Forged Stroker Voodoo Crank
Double roller billet roadmaster timing chain w/ Torrington Bearing /ARP Bolt
Melting Oil pump 10355
ARP 234-4317 Head studs
LS3 CNC 320cc Heads 260cc/64cc
Lunati Voodoo blower cam 2054LS3S3 233/250 618/595 113+5
Ultra pro magnum XD roller rocker arms 1.8
Johnson Bar Link Lifters ST2116LSR
LS9 Head Gasket
Manley 25767-16 Chrome Moly .080 Wall 5/16 Pushrods 7.600
King Racing CR 807XPN
King Engine Bearing MB5013XP Main Bearing
ATI Super Damper 918635 harmonic damper
Procharger F1A-94 W/3 core intercooler
3 bar map sensor
Holley LS3-L92- 105mm Hi - Ram Black Intake
Holley Injectors 160lbs 522-168FM
AEM Water/Methanol Injection Kits 30-3300
2005. Lq4 408
LS9 Head Gasket
3 bar map sensor
Yeah at the wheel..Still need a surge tank or something..I also will be running e85 plus I still have the option of running my F1X Procharger also..
n20king
Mar 28, 2011 06:45 PM
thunder550
28
Dec 13, 2006 05:23 PM
