Looking for a supercharger any ideas
So I recently 4l80 swapped my ls gmt400 2 door blazer (02 5.3 with exhaust and a cam ~30k miles since I rebuilt and swapped it in), it’s now very underwhelming and I’ve always wanted to throw a PD blower on it. Ie a Magnuson or Whipple (and not that ugly side mount stuff). It’s a winter daily and part time summer vehicle in alaska, so it sees from -50 to 90 degrees. So reliability is a major factor and I figured one of these would be the best way to add some reliable power. I already own a turbo 55 pickup and a CTSV, not looking for fastest but just some more go.
However aside from a brand new $6k+ kit I can’t find anything used. I’d be happy with either a 1900 or 2300, just seems like there would be more of these for sale. Anyone have some leads on one of these, I’d even settle for a partial kit at this point.
They were more budget friendly but prices have gone up a lot.
A used LSA blower is $1,500ish or more on ebay and a new ZL1 lid is $700-800 now. Add in the CSTV fuel rail, injectors, adapter plates or swap cylinder heads, intercooler, pump, wiring, map sensor, whatever else and it's over $4,000 now.
Someone local to me has an intercooled p1sc kit for a 88-98 chevy, I could get a bracket to mount the head unit to an LS. Just wasn’t sure if the p1sc would make decent power. I was hoping for 500 to the tire.
With enough boost you'll get to 450-500hp no problem. It just won't have that low end grunt because it's a procharger.
How much boost it takes can vary. What fuel you run, how much timing and how big the camshaft is.
I made 477 on 12lbs with a P1, through a 100% stock GMT800 exhaust
Im changing everything now. Different cam, long tubes, D1 conversion, 8 rib, overdrive lower and waste gate. I have all this done, but of course im
waiting on the 4L60 to finish dying so I can swap to a 6L80 and put it all together
P1 will get you what you want if your cam and exhaust will let it
My 370/whipple combo made 483 @ 8psi on a fat tune.
The difference from 8psi to 10psi was noticeable.
When I put the 2.5in pulley on it, it made just over 14psi. I ran pure Redline Water Wetter in the SC cooling system.
That thing was stupid by this point. 0 traction in the first 3 gears.
**** tends to break more with the more boost you run.
