needing more what to do???
Old Dec 24, 2007 | 03:09 PM
05crew's Avatar
Default needing more what to do???
well after a week for 6lbs and 2 tires later! i am looking for a little more power!! the info im looking for is would it be better to keep 6lbs of boost and spray a 125 lets say. or put a 2.7 pulley on and some meth? what would make more power?
Old Dec 24, 2007 | 03:13 PM
dan96z71's Avatar
Same with me....6 lbs is just not enough. I have kept the tires on it, they only start to spin at about 25-30 mph.
Old Dec 24, 2007 | 03:18 PM
05crew's Avatar
same here with 488rwhp to the black top
Old Dec 24, 2007 | 03:23 PM
dan96z71's Avatar
I don't know what I actually have at the rear wheels, but I would say somewhere in the 350 range I would guess. I was hoping that the 6 lbs would be enough for me....but no luck.
Old Dec 24, 2007 | 03:24 PM
dan96z71's Avatar
No reason not to get to the 500 mark if you ask me! Or 550 for that matter.
Old Dec 24, 2007 | 05:23 PM
thunder550's Avatar
High on diesel fumes
I'd bump up the boost instead of running nitrous. Boost is fantastic....a couple psi and you feel like you have a whole new truck Adding 3 psi at the track last weekend took me from a 12.32 to an 11.63.
Old Dec 24, 2007 | 05:38 PM
05crew's Avatar
if i have 6psi with a 3.0 what would a 2.7 do. and im making 488 hp, what is the rwhp per lbs of boost so i could guess what 3psi would do. would i need meth?
thanks for the help
dan96z71's Avatar
I would do the pulley also.
Old Dec 24, 2007 | 07:42 PM
05crew's Avatar
does any one no what 1psi = rwhp
Old Dec 24, 2007 | 08:31 PM
WorkTruc's Avatar
Usually about 20 hp
