needing more what to do???
Here's a good thread that should answer that question pretty well...
https://www.performancetrucks.net/fo...d.php?t=404647
9 Second Truck Club
It just depends on where you are in your efficiency range. With my 6.0, and t66 going from 6-10psi was a HUGE difference, but I gained nothing from 10-12psi. Just by swaping over to the T76 even at the same 12psi I gained big power. The T76 leaned out my AFR from below 10 to 11.2, at the same 12psi. That just shows one turbo is out of it's range, and the other is just right. Seems like the T76 is done around 15PSI. I think you might have a nice gain going from 6 to 8psi. I don't know where that blower will run out of breath but I would think 10psi would be spinning it pretty hard.
you asked about meth above. you need a radix guy to post up on this but i think you start needing that stuff above 9psi. that what i have seen on other intercooled truck set ups.
